Печальная весть. Ушёл в лучший мир член команды WSJT-X Bill Somerville, G4WJS.
Устанавливается,
root@video:~/Downloads# /usr/lib/mc/extfs.d/deb run /home/websdr/Downloads/jtdx-2.2.157-rc0_i386.deb INSTALL
Installing /home/websdr/Downloads/jtdx-2.2.157-rc0_i386.deb
Selecting previously unselected package jtdx.
(Reading database ... 354020 files and directories currently installed.)
Preparing to unpack .../jtdx-2.2.157-rc0_i386.deb ...
Unpacking jtdx (2.2.157-rc0) ...
Setting up jtdx (2.2.157-rc0) ...
Processing triggers for man-db (2.7.5-1) ...
но выдает ошибку при запуске
websdr@video:~$ jtdx
jtdx: error while loading shared libraries: libQt5WebSockets.so.5: cannot open shared object file: No such file or directory
Виктор, сделайте так:
sudo apt-get install libqt5websockets libqt5websockets-dev
И скачайте другую сборку (я все-так на всякий случай обновил boost до 1.63):
https://cloud.mail.ru/public/vfcu/84as4cTjC
SHA256: 18bf698463337afc7258b515182d0d2027f598b63bc2382dd2e10c7e45dd9616
Пробуйте (возможно тоже надо доустановить libqt5websockets-dev):
https://cloud.mail.ru/public/FtXs/AKKioBXoQ
SHA256: be72d298956031a86d989b206fb1210647936e73f0960d2159977aa61bb12df4
root@video:~/Downloads# apt-get install libqt5websockets5 libqt5websockets5-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libqt5websockets5 : Depends: qtbase-abi-5-5-1
libqt5websockets5-dev : Depends: qtbase5-dev
E: Unable to correct problems, you have held broken packages.
root@video:~/Downloads# apt-get install qtbase-abi-5-5-1
Package qtbase-abi-5-5-1 is a virtual package provided by:
libqt5core5a 5.5.1+dfsg-16ubuntu7.7 [Not candidate version]
libqt5core5a 5.5.1+dfsg-16ubuntu7 [Not candidate version]
E: Package 'qtbase-abi-5-5-1' has no installation candidate
root@video:~/Downloads# apt-get install qtbase5-dev
qtbase5-dev : Depends: libqt5concurrent5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5core5a (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5dbus5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5gui5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5network5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5printsupport5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5sql5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5test5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5widgets5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: libqt5xml5 (= 5.5.1+dfsg-16ubuntu7.7) but 5.6.1+dfsg-3ubuntu1~xenialoverlay1~4+fix1 is to be installed
Depends: qtbase5-dev-tools (= 5.5.1+dfsg-16ubuntu7.7) but it is not going to be installed
Recommends: libqt5opengl5-dev (= 5.5.1+dfsg-16ubuntu7.7)
Трудно, возвращаюсь на 155 :s9:
