Цитата:
The CAT commands are Kenwood CAT based. Therefore the Error Codes are as follows:
■ Error Messages
In addition to the Answer command, the transceiver can send the error messages listed below
Error
Message Reason for Error
•Command syntax was incorrect.
•Command was not executed due to
the current status of the transceiver
(even though the command syntax
was correct).
Note: Occasionally, this message may not
appear due to microprocessor transients in
the transceiver.
E;
A communication error occurred, such
as an overrun or framing error during a
serial data transmission.
O;
Receive data was sent but processing
was not completed.
так что ответ в виде ;? при отключённом ГПД В - верный
