Что-то я совсем в ступоре...
Если мы сдвинем опору, то боковая полоса сама по себе РАЗВЕРНЕТСЯ??? И не нужно формирователь SSB никак переключать???
Хотя, конечно, все может быть, нужно подумать...
Все, спасибо, понял.. Вместе с опорой уедет все, а фильтр-то не уедет... И в него другая боковая попадет..
Вот ещё один пост по решению проблемы дискретизации.
Joe W4TV wrote:
> > Vista, Windows 7 and Windows 8 all have problems with
> > resampling when the default sample rate and the requested
> > sample rate are not integer factors. ...
> > Integral factors can simply "throw away" the unneeded samples.
Joe K1JT replied:
> For the record: actually that's a *very* bad way to do integral-factor
> downsampling, unless the data have already been low-pass filtered in
> either hardware or software with a stop-band starting frequency no
> higher than half the output sample rate.
> This is one of the reasons that WSJT-X now samples at 48 kHz, by
> default, and does its own (high-quality) downsampling.
Lots of issues with the redesign of the audio subsystem in Windows Vista.
When an audio driver supports both 44.1 kHz and 48 kHz Microsoft decided to
default to 44.1 kHz - likely due to the belief that there was more content
out there that has been sampled at the redbook (CD) rate.
A couple of years ago I ran into an issue playing out audio at a rate that
was different than what the card was set for. Windows has a number of
different sample rate conversion routines. DirectSound was OK - but
applications that use the waveOut API had the problem. This was
acknowledged as a bug and because of common code affects both waveOut and
waveIn. A hotfix was released; I don't know if this has been rolled into
any subsequent Windows 7 update. Here's a link to the hotfix article:
Audio file sounds distorted after you convert the sample rate in Windows 7 or in Windows Server 2008 R2
The nice thing about Windows 7 - I can setup my microHAM boxes with their
own audio interfaces (in Windows) and fix the sample rate to 48000 Hz for
use with WSJT ... and then use a separate audio device (like on the
motherboard or add-in card like Soundblaster, etc.) for normal computer
audio ... which can be set to whatever rate you need/desire.
Bob W1QA
06:49 3 -14 -0.2 716 B RX5DX 4S7KKG -07 на 15ке..
это уже у меня 120 ДХСС
Очередное обновление JT65-HF-Comfort-4
Файл exe only (v4.0.0.332a) http://abcsolutions.de/jt65hf/jt65-hf-comfort_332a.exe
Нужно копировать с правом доступа.
Вложение 113591
Штампуют, уже 345а версия.
Вроде как перезалили версию (v4.0.0.345a) http://abcsolutions.de/jt65hf/jt65-hf-comfort-setup.exe
Внесли исправления.
