в цифре везде верхняя боковая. К сожалению, в программе это по звуку не перееключается. В отличие от программного обеспечения для работы PSK и RTTY разных видов.
Вот из форума ответ по решению проблемы. Переводчик из меня аховый поэтому думаю что без моей помощи поймёте что надо в wsjtx.ini файл с помощью редактора добавить две строки в конце файла если по ряду причин не можите выбрать частоту дискретизации 48 кГц:
[Tune]
Audio\DisableInputResampling=true
Hi Rein & Charlie,
I'm also replying to the group since it looks like a few are having problems with sample rates.
To all, this post is about failure to decode any signals from a reasonable looking WF on versions r3590 and later.
First check your clock, poor clock synchronization is a common cause of failure to decode.
WSJT-X v1.3 completes a migration to using Qt for audio handling. The RX direction is new in v1.3.
Because of some issues on non-Windows platforms we choose to request a 48kHz audio input stream from the operating system. Before we were requesting a 12kHz stream. 12kHz is quite sufficient for our needs but on Mac OS-X we couldn't find a way to get 12kHz to work.
In theory downsampling from 48kHz to 12kHz is a trivial operation, unfortunately MS Windows has issues with sample rate conversions and sharing soundcards between applications. For example on Vista it seems to work at a base rate of 44.1kHz and convert from that, but the math is broken somewhere and serious distortion results. To deal with Vista we put in an optional 12kHz stream request, this is selected automatically on Vista systems.
On Windows 7 and later things are a lot better and simply setting a default sample rate for your soundcard of 48kHz works great.
On Windows XP the sound subsystem is largely in the hands of the individual soundcard drivers. We cannot document where the setting of default sample rate is because it varies from driver to driver. The setting should be available from the "Control Panel" sound applet. If you can't find the setting because the driver writer hasn't made it available, or if your soundcard only goes up to 44.1kHz then all is not lost. You don't need to buy a new external soundcard. There is a hidden tuning parameter that you can add to the wsjtx.ini file for force it to request a 12kHz input audio stream.
If you cannot find a way to select a 48kHz sample rate for sound input then using and editor of your choice, open the wsjtx.ini file (it's in the same directory as the executable) and add the following two lines to the end of the file:
[Tune]
I would appreciate report of who has to use this and if it works.
Bill
G4WJS.
Вывод напрашивается такой; надо уходить от XP, от Висты, от старых устройств с ихними устаревшими драйверами.
Новое обновление JT65-HF-Comfort-4
Файл exe only (v4.0.0.261a) http://abcsolutions.de/jt65hf/jt65-hf-comfort_261a.exe
вот, что интересно:
there's been an interesting discussion going on with Ulrich, DK4VW, chairman of the IARU region 1 HF commitee. The result is that 3576 kHz might not be compliant with the band plans for our IARU region and therefore has been changed to 3586 kHz in the frequency selection list. You can still use the old non-compliant QRG, of course, by simply defining an additional QRG in the settings. But please remember: you shouldn't!!
в автопереводе:
- Там было интересное обсуждение происходит с Ульрихом, DK4VW, председателем 1 района IARU HF комитета. Результатом является то, что 3576 кГц не может быть совместимо с планами группы для нашего IARU региона и, следовательно, был изменен на 3586 кГц в списке выбора частоты. Вы все еще можете использовать старый несовместимый QRG, конечно, просто определяя дополнительный QRG в настройках. Но, пожалуйста, помните: вы не должны!
Придется на 80-ке переезжать на 10 кгц выше
Ничего нового HF
pdf файл:Вложение 113455
