Like Tree17119Спасибо
  1. #5476
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    JTDX v17.6: Результаты тестирования
    Test results, JT65a, number of decoding attempts=1, decoding passes=4:
    Wideband experience based Hint decoder
    test Web SDR audio files https://cloud.mail.ru/public/LrVm/zEkJ1ZVLg
    CALL3.TXT file as of November 2nd, 2016, 21570 records
    SW version / total JT65 decodes / BM-FTRSD decodes / wideband CQ/CQ DX Hint / experience based Hint / JT9 /
    v17.2 Hint OFF / 3087 / 3087 / - / - /
    v17.2 Hint ON / 3296 / 3055 / 61* / 180* / - /
    v17.3 Hint ON / 3315 / 3028 / 94* / 193* / - /
    v17.4 Hint OFF / 3123 / 3123 / - / - / 374 / # AGCc is OFF
    v17.4 Hint OFF / 3162 / 3162 / - / - / 378 / # AGCc is ON
    v17.4 Hint ON / 3355 / 3064 / 98 / 193 / - / # AGCc is OFF
    v17.4 Hint ON / 3432 / 3083 / 127 / 222 / - / # AGCc is ON
    v17.5 Hint ON / 3332 / 3060 / 100 / 172 / - / # AGCc is OFF
    v17.6 Hint OFF / 3118 / 3118 / - / - / 374 / # AGCc is OFF frequency mask is OFF
    v17.6 Hint OFF / 3158 / 3158 / - / - / 377 / # AGCc is ON frequency mask is OFF
    v17.6 Hint OFF / 3174 / 3174 / - / - / 377 / # AGCc is ON frequency mask is ON
    *it is not possible to confirm every hinted CQ/CQ DX decode from these
    SDR audio files is correct one.
    SDR audio files with more than 20 signals in each file, decoding test results:
    test files: https://cloud.mail.ru/public/9Dfk/xrP5GvfYR
    correct/ false decodes
    v16.4 hint off 3172/6
    v16.6 hint off 3168/7
    v16.7 hint off 3189/9
    v16.8 hint off 3198/3
    v16.9 hint off 3214/6
    v16.9.1 hint off 3229/1
    v17.0.1 hint off 3230/2
    v17.1 hint off 3231/4
    v17.2 hint off 3232/5
    v17.3 hint off 3232/0
    v17.4 hint off 3228/1
    v17.5 hint off 3227/0
    v17.5.2 hint off 3231/1
    v17.6 hint off 3202/1 frequency mask is OFF
    v17.6 hint off 3231/2 frequency mask is ON
    v16.4 hint on 3248/4 * --- CALL3.TXT/20480 records
    v16.6 hint on 3251/4 * --- CALL3.TXT/20480 records
    v16.7 hint on 3272/9 * --- CALL3.TXT/20480 records
    v16.8 hint on 3284/4 * --- CALL3.TXT/20480 records
    v16.9 hint on 3300/7 * --- CALL3.TXT/20480 records
    v16.9.1 hint on 3306/1 * --- CALL3.TXT/20480 records
    v17.0.1 hint on 3304/1 * --- CALL3.TXT/21570 records
    v17.1 hint on 3310/4 * --- CALL3.TXT/21570 records
    v17.2 hint on 3354/3 * --- CALL3.TXT/21570 records
    v17.3 hint on 3376/0 * --- CALL3.TXT/21570 records
    v17.4 hint on 3372/0 * --- CALL3.TXT/21570 records
    v17.5 hint on 3366/1 * --- CALL3.TXT/21570 records
    v17.5.2 hint on 3361/3 * --- CALL3.TXT/21570 records
    v17.6 hint on 3350/1 * --- CALL3.TXT >25000 records frequency mask is OFF
    v17.6 hint on 3349/5 * --- CALL3.TXT >25000 records frequency mask is ON
    for decoding attempts=3:
    v16.4 hint off 3218 total
    v16.6 hint off 3217 total
    v16.7 hint off 3223/4
    v16.8 hint off 3225/1
    v16.9 hint off 3233/5
    v16.9.1 hint off 3247/5
    v17.0.1 hint off 3244/2
    v17.1 hint off 3255/1
    v17.2 hint off 3252/1
    v17.3 hint off 3256/0
    v17.4 hint off 3256/3
    v17.5 hint off 3250/3
    v17.5.2 hint off 3245/2
    v17.6 hint off 3244/2 frequency mask is OFF
    v17.6 hint off 3251/3 frequency mask is ON
    FTRSD weak signal decoding, -25dB SNR simulated signals, 10 signals in each file,
    200 files used for test, all signals are out of RX frequency, decoding probability:
    test files: https://cloud.mail.ru/public/7SYw/BNWYg6hTJ
    v17.5 hint off 23.2% # AGCc is OFF
    v17.5.2 hint off 22.1% # AGCc is OFF
    v17.6 hint off 34.4% # AGCc is OFF frequency mask is OFF
    200 files used for test, decoding on the QSO frequency 1000Hz, decoding probability:
    v17.5 hint off 50.0% # AGCc is OFF
    v17.5.2 hint off 48.5% # AGCc is OFF
    v17.6 hint off 51.0% # AGCc is OFF frequency mask is OFF
    Per pass decoding statistics, number of decodes, audio files with more than 20 signals
    in the file, hint off:
    v16.1, number of decodes:
    pass 1 subpass 1 2502 80%
    pass 1 subpass 2 152 5%
    pass 1 total 2654 85%
    pass 2 364 11%
    pass 3 95 3%
    pass 4 34 1%
    __________________________________
    * Для декодирований широкополосных декодеров CQ/CQ DX из SDR файлов невозможно определить все ли полученные декодирования верны.
  2. #5477
    Big Gun Аватар для RX4CD
    02.01.2009
    SA-43
    11,113
    5507
    2771
    Что-то я не вижу здесь - JTDX нового файла CALL3. Есть только за 03.01.2017г.
    И что-то у себя в программе я не вижу файла ini.
    Открывал по адресу - JTDX - Fail - Open log directory.
  3. #5478
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    Новый CALL3 идет в комплекте с новым софтом. На сайте пока решили не публиковать из-за несовместимости со старым софтом.
  4. #5479
    Пацифист Аватар для R0AEB
    25.07.2016
    Красноярск
    115
    35
    161
    Ждемс когда Олег привяжет к EQF
  5. #5480
    27.11.2010
    69
    266
    100
    фильтр понравился Птицу поставил и не одной европейской станции.
  6. #5481
    Big Gun Аватар для R6LCF
    21.04.2015
    г.Таганрог
    5,119
    1533
    1116
    Ждем!
  7. #5482
    17.05.2010
    131
    69
    182
    Коллеги, столкнулся сегодня с небольшой проблемкой. При декодировании всех принятых сигналов появляются позывные в левом окне в течении от секунды до нескольких секунд и, если декодируемых сигналов очень много (25 и больше), пытаясь выбрать нужный позывной просто "промахиваешься" мышкой по нужной строчке в процессе декодирования, при этом передача уже включается и я понимаю, что выбран был не тот позывной.
    Есть ли другая возможность выбора нужной строчки из левого окна? Например, курсор автоматически становится на первую строчку декодированного сигнала и через ctrl+up/down можно было бы выбрать нужную строку.
    Скорее вопрос к Игорю. Но хотелось бы услышать мнения "бывалых".
    Сегодня насчитал максимальное число декодированных сигналов за один период приема, их было 34 на 20-ке. И они (строки) заполнили всё левое окно. А что будет при еще бОльшем кол-ве декодированных сигналов!?
  8. #5483
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    набор из пяти звуковых файлов, в каждом 200 JT65 сигналов в полосе от 5 до 2695 Гц https://cloud.mail.ru/public/Cmeh/TfXoewPMa
    для тестирования на версии 17.6
  9. #5484
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    По опыту использования действительно лучше коллег спросить, еще прошедшим летом я сам нередко промахивался, а с точки зрения софта теперь должна помочь фильтрация сообщений со сработанными корреспондентами и в крайнем случае фильтрация части континентов.
  10. #5485
    Координатор темы
    01.07.2011
    Днепропетровск
    3,069
    3092
    246
    JTDX-17.6.0 for UR5EQF
    или
    Персональный сайт - JTDX for UR5EQF_Log3
    В архив включён файл CALL3.TXT.
    И сразу, не красиво смотрится
  11. #5486
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    поддержка опциональных интерфейсов в JTDX
    По причине того что в сборках стало ощутимо заметно смещение динамического диапазона, поиск сборки с хорошими результатами стал занимать очень много времени, и я вынужден пока отложить поддержку опциональных интерфейсов пользователя.
    Всем кто будет делать изменения в коде либо заново собирать софт самостоятельно пригодится набор тестовых файлов c сигналами -25дБ SNR который находится здесь https://cloud.mail.ru/public/7SYw/BNWYg6hTJ
    и для сравнения результаты тестирования выпущенной версии 17.6 для сравнения, файлы прикладываю. Тестирование для слабых сигналов проводилось при уровне шума +40дБ и RX частоте 1503 Гц, нижняя граница 0 Гц, верхняя 3500 Гц, режим JT65+JT9, все кнопки выключены, остальные установки на приложенной картинке.
    Изображения Изображения
    Вложения Вложения
  12. #5487
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    в 17.6.1 и далее сделаю зазор в 1..2 пикселя, также зазор появляется при увеличении размера окна интерфейса.
  13. #5488
    30.12.2011
    59
    153
    26
    43
    Правильно ли работает "Check other standart messages"? Не отмечен, а выделяет. Раньше если не ставил здесь галку, то и вариант "Other standart message" не отображался.
  14. #5489
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    Зазор между кнопкой и часами исчезает если размер шрифта выбран менее чем 9, на 9 и более зазор есть. У меня шрифт 10 стоял, во время тестов не заметил проблемы.
  15. #5490
    Very High Power Аватар для EW6BN
    15.08.2006
    50
    1,480
    727
    627
    Игорь, спасибо за 17,6.
    Заметил такой баг, в 17.5.2 он тоже есть.
    Если префикс локатора совпадает с домашим, например мой KO45 и локатор корреспондента вида KOx5 то расстояние =0, вместо х-любая цифра.
    Если например мой IN87, то нуль будет при локаторе корреспондента вида INx7.
    Ответов: 65
  2. Как начать работать с CW?
    от Z80X в разделе Телеграф
  3. Новая мода JT65
    от RX3AOE в разделе Win-XP/7
