26.02.2017, 17:37 #5476
- 05.03.2015
- 5,570
- 7959
- 807
JTDX v17.6: Результаты тестирования
Test results, JT65a, number of decoding attempts=1, decoding passes=4:
Wideband experience based Hint decoder
test Web SDR audio files https://cloud.mail.ru/public/LrVm/zEkJ1ZVLg
CALL3.TXT file as of November 2nd, 2016, 21570 records
SW version / total JT65 decodes / BM-FTRSD decodes / wideband CQ/CQ DX Hint / experience based Hint / JT9 /
v17.2 Hint OFF / 3087 / 3087 / - / - /
v17.2 Hint ON / 3296 / 3055 / 61* / 180* / - /
v17.3 Hint ON / 3315 / 3028 / 94* / 193* / - /
v17.4 Hint OFF / 3123 / 3123 / - / - / 374 / # AGCc is OFF
v17.4 Hint OFF / 3162 / 3162 / - / - / 378 / # AGCc is ON
v17.4 Hint ON / 3355 / 3064 / 98 / 193 / - / # AGCc is OFF
v17.4 Hint ON / 3432 / 3083 / 127 / 222 / - / # AGCc is ON
v17.5 Hint ON / 3332 / 3060 / 100 / 172 / - / # AGCc is OFF
v17.6 Hint OFF / 3118 / 3118 / - / - / 374 / # AGCc is OFF frequency mask is OFF
v17.6 Hint OFF / 3158 / 3158 / - / - / 377 / # AGCc is ON frequency mask is OFF
v17.6 Hint OFF / 3174 / 3174 / - / - / 377 / # AGCc is ON frequency mask is ON
*it is not possible to confirm every hinted CQ/CQ DX decode from these
SDR audio files is correct one.
SDR audio files with more than 20 signals in each file, decoding test results:
test files: https://cloud.mail.ru/public/9Dfk/xrP5GvfYR
correct/ false decodes
v16.4 hint off 3172/6
v16.6 hint off 3168/7
v16.7 hint off 3189/9
v16.8 hint off 3198/3
v16.9 hint off 3214/6
v16.9.1 hint off 3229/1
v17.0.1 hint off 3230/2
v17.1 hint off 3231/4
v17.2 hint off 3232/5
v17.3 hint off 3232/0
v17.4 hint off 3228/1
v17.5 hint off 3227/0
v17.5.2 hint off 3231/1
v17.6 hint off 3202/1 frequency mask is OFF
v17.6 hint off 3231/2 frequency mask is ON
v16.4 hint on 3248/4 * --- CALL3.TXT/20480 records
v16.6 hint on 3251/4 * --- CALL3.TXT/20480 records
v16.7 hint on 3272/9 * --- CALL3.TXT/20480 records
v16.8 hint on 3284/4 * --- CALL3.TXT/20480 records
v16.9 hint on 3300/7 * --- CALL3.TXT/20480 records
v16.9.1 hint on 3306/1 * --- CALL3.TXT/20480 records
v17.0.1 hint on 3304/1 * --- CALL3.TXT/21570 records
v17.1 hint on 3310/4 * --- CALL3.TXT/21570 records
v17.2 hint on 3354/3 * --- CALL3.TXT/21570 records
v17.3 hint on 3376/0 * --- CALL3.TXT/21570 records
v17.4 hint on 3372/0 * --- CALL3.TXT/21570 records
v17.5 hint on 3366/1 * --- CALL3.TXT/21570 records
v17.5.2 hint on 3361/3 * --- CALL3.TXT/21570 records
v17.6 hint on 3350/1 * --- CALL3.TXT >25000 records frequency mask is OFF
v17.6 hint on 3349/5 * --- CALL3.TXT >25000 records frequency mask is ON
for decoding attempts=3:
v16.4 hint off 3218 total
v16.6 hint off 3217 total
v16.7 hint off 3223/4
v16.8 hint off 3225/1
v16.9 hint off 3233/5
v16.9.1 hint off 3247/5
v17.0.1 hint off 3244/2
v17.1 hint off 3255/1
v17.2 hint off 3252/1
v17.3 hint off 3256/0
v17.4 hint off 3256/3
v17.5 hint off 3250/3
v17.5.2 hint off 3245/2
v17.6 hint off 3244/2 frequency mask is OFF
v17.6 hint off 3251/3 frequency mask is ON
FTRSD weak signal decoding, -25dB SNR simulated signals, 10 signals in each file,
200 files used for test, all signals are out of RX frequency, decoding probability:
test files: https://cloud.mail.ru/public/7SYw/BNWYg6hTJ
v17.5 hint off 23.2% # AGCc is OFF
v17.5.2 hint off 22.1% # AGCc is OFF
v17.6 hint off 34.4% # AGCc is OFF frequency mask is OFF
200 files used for test, decoding on the QSO frequency 1000Hz, decoding probability:
v17.5 hint off 50.0% # AGCc is OFF
v17.5.2 hint off 48.5% # AGCc is OFF
v17.6 hint off 51.0% # AGCc is OFF frequency mask is OFF
Per pass decoding statistics, number of decodes, audio files with more than 20 signals
in the file, hint off:
v16.1, number of decodes:
pass 1 subpass 1 2502 80%
pass 1 subpass 2 152 5%
pass 1 total 2654 85%
pass 2 364 11%
pass 3 95 3%
pass 4 34 1%
__________________________________
* Для декодирований широкополосных декодеров CQ/CQ DX из SDR файлов невозможно определить все ли полученные декодирования верны.Последний раз редактировалось UA3DJY; 26.02.2017 в 17:46.
26.02.2017, 17:43 #5477
- 02.01.2009
- SA-43
- 10,792
- 5342
- 2602
Что-то я не вижу здесь - JTDX нового файла CALL3. Есть только за 03.01.2017г.
И что-то у себя в программе я не вижу файла ini.
Открывал по адресу - JTDX - Fail - Open log directory.
Последний раз редактировалось RX4CD; 26.02.2017 в 17:49.
73. Сергей.
26.02.2017, 17:54 #5478
- 05.03.2015
- 5,570
- 7959
- 807
26.02.2017, 18:01 #5479
- 25.07.2016
- Красноярск
- 115
- 35
- 161
Ждемс когда Олег привяжет к EQF
Александр r0aeb 73
Give Peace A Chance
26.02.2017, 18:25 #5480
- 27.11.2010
- 260
- 100
фильтр понравился Птицу поставил и не одной европейской станции.
RA3RKA
26.02.2017, 18:33 #5481
26.02.2017, 20:14 #5482
- 17.05.2010
- 125
- 173
Коллеги, столкнулся сегодня с небольшой проблемкой. При декодировании всех принятых сигналов появляются позывные в левом окне в течении от секунды до нескольких секунд и, если декодируемых сигналов очень много (25 и больше), пытаясь выбрать нужный позывной просто "промахиваешься" мышкой по нужной строчке в процессе декодирования, при этом передача уже включается и я понимаю, что выбран был не тот позывной.
Есть ли другая возможность выбора нужной строчки из левого окна? Например, курсор автоматически становится на первую строчку декодированного сигнала и через ctrl+up/down можно было бы выбрать нужную строку.
Скорее вопрос к Игорю. Но хотелось бы услышать мнения "бывалых".
Сегодня насчитал максимальное число декодированных сигналов за один период приема, их было 34 на 20-ке. И они (строки) заполнили всё левое окно. А что будет при еще бОльшем кол-ве декодированных сигналов!?Последний раз редактировалось UN7LZ; 26.02.2017 в 20:52.
73, Valery UN7LZ
26.02.2017, 20:52 #5483
- 05.03.2015
- 5,570
- 7959
- 807
набор из пяти звуковых файлов, в каждом 200 JT65 сигналов в полосе от 5 до 2695 Гц https://cloud.mail.ru/public/Cmeh/TfXoewPMa
для тестирования на версии 17.6
26.02.2017, 20:56 #5484
- 05.03.2015
- 5,570
- 7959
- 807
26.02.2017, 21:03 #5485
- 01.07.2011
- Днепропетровск
- 2,998
- 2951
- 220
JTDX-17.6.0 for UR5EQF
или
Персональный сайт - JTDX for UR5EQF_Log3
В архив включён файл CALL3.TXT.
И сразу, не красиво смотрится
Последний раз редактировалось US-E-12; 26.02.2017 в 21:07.
26.02.2017, 21:09 #5486
- 05.03.2015
- 5,570
- 7959
- 807
поддержка опциональных интерфейсов в JTDX
По причине того что в сборках стало ощутимо заметно смещение динамического диапазона, поиск сборки с хорошими результатами стал занимать очень много времени, и я вынужден пока отложить поддержку опциональных интерфейсов пользователя.
Всем кто будет делать изменения в коде либо заново собирать софт самостоятельно пригодится набор тестовых файлов c сигналами -25дБ SNR который находится здесь https://cloud.mail.ru/public/7SYw/BNWYg6hTJ
и для сравнения результаты тестирования выпущенной версии 17.6 для сравнения, файлы прикладываю. Тестирование для слабых сигналов проводилось при уровне шума +40дБ и RX частоте 1503 Гц, нижняя граница 0 Гц, верхняя 3500 Гц, режим JT65+JT9, все кнопки выключены, остальные установки на приложенной картинке.Последний раз редактировалось UA3DJY; 26.02.2017 в 21:12.
26.02.2017, 21:13 #5487
- 05.03.2015
- 5,570
- 7959
- 807
26.02.2017, 21:51 #5488
- 30.12.2011
- Волгоград
- 152
- 26
- 43
26.02.2017, 22:11 #5489
- 05.03.2015
- 5,570
- 7959
- 807
26.02.2017, 22:55 #5490
Игорь, спасибо за 17,6.
Заметил такой баг, в 17.5.2 он тоже есть.
Если префикс локатора совпадает с домашим, например мой KO45 и локатор корреспондента вида KOx5 то расстояние =0, вместо х-любая цифра.
Если например мой IN87, то нуль будет при локаторе корреспондента вида INx7.
7373! Юрий EW6X (ex EW6BN) Если не QRP, то 100Вт@палка/верёвка
