26.12.2020, 15:47 #151QRPP
- 22.12.2020
Hi Alexei
I tried as you suggested regarding translating the User2 -> SOTA_REF for ADIF export but I can't get this to work. When I examine the ADIF export in ADIF Master the User1/User2 and User3 fields are populated, the transformation of User fields via the ADIF Setup page doesn't work for me. Maybe there is something else I should be doing.
I am exporting using the menu item File -> Export -> ADIF Format
Many thanks, Mark M0NOM
26.12.2020, 20:52 #152Координатор темы
- 03.02.2006
- 53
- 20,458
- 10078
- 5414
Fixed!
What version of log do you use? May be problem here - use this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_604.exe
Yes, you can itself correct WFF award.
But you must remember: DLFF-0093 is not equal DL-093! Set for QSO field WFF as in award format!73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
26.12.2020, 22:14 #153QRPP
- 22.12.2020
Hi Alexei
Yes, the 604 version works correctly, thank you, and seasons greetings.
Regards, Mark. M0NOM
03.01.2021, 23:49 #154Standart Power
- 03.01.2021
- 196
- 18
Good evening everyone.
I found this problem in the "New qso Entry" window.
If I enter RX4HX, it correctly goes to read the fields on QRZ.COM (so I configured it), and then automatically inserts them in the registration window of the qso.
But if I enter RX4HX/p or RX4HX/m it does not read any data on QRZ.COM.
In this case it should read only the full name field (FName + Name) and the e-mail field, leaving the QTH, State, County, and WWLoc field blank
because being in portable or mobile I will have to enter other data (other place) provided by the correspondent.
I hope I was clear in the explanation.
Thanks for the attention
73 de IK2XDE Andrea.
Good evening,
sorry, I've been using LogHX (v3.0 build 604) for a few days,
the management of the awards not clear to me.
In the process of entering a qso, where I can enter the reference of the desired award .. ??
For example .... if I am in qso with DL8AAM, I would like to insert the appropriate DOK reference,
but in the window "qso entry" there is only the possibility to choose the IOTA (drop-down menu)
and WFF .... which seem does not work, there is no reference....no drop-down menu.
Thanks for the attention.
04.01.2021, 00:08 #155Координатор темы
- 03.02.2006
- 53
- 20,458
- 10078
- 5414
04.01.2021, 00:20 #156Standart Power
- 03.01.2021
- 196
- 18
ok works, but the command works in reverse.
Thanks.
04.01.2021, 11:52 #157Координатор темы
- 03.02.2006
- 53
- 20,458
- 10078
- 5414
04.01.2021, 21:24 #158Standart Power
- 03.01.2021
- 196
- 18
Good evening,
but in the window "qso entry" there is only the possibility to choose the IOTA (drop-down menu...ok)
For the other award.....where I put the reference....??
04.01.2021, 21:25 #159Координатор темы
- 03.02.2006
- 53
- 20,458
- 10078
- 5414
You can setup QSOEntry window as you like - look here:
https://forum.qrz.ru/355-loghx-appar...ml#post1688916
you can set count visible fields and set fields name.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
04.01.2021, 21:38 #160Standart Power
- 03.01.2021
- 196
- 18
OK, but that's not my problem.
I have already put 10 lines and all fields.
The problem is that the IOTA field offers the drop-down menu with references
the WFF field does not offer any drop-down menus and no references.
And then if I wanted to put another award type RDA how do I put it .. ??
Thanks.
04.01.2021, 22:42 #161Standart Power
- 03.01.2021
- 196
- 18
In the right part of the "qso entry" window I have activated the buttons,
how can I do to activate only some and not all ..?
I would like to use only the "find" button.
Among other things, I suggest separating the information
FIND CALL: QRZ.COM - QRZ.RU - HAMQTH - Clublog - EQSL
FIND MANAGERS: IK3QAR Site - QSLInfo.de - Local File Manager
FIND OTHER INFO: 425DXN - DXSUMMIT
So three different buttons for the three choices
Thanks.
73 de IK2XDE Andrea
04.01.2021, 23:56 #162QRP
- 26.10.2019
- 46
- 17
- 9
FT4 (qsl confirmation), from LoTW and eQS
Hello,
LogHX users.
How to configure logHX, v.3.0 build 606, to obtain FT4 (qsl confirmation), from LoTW (R) and eQSL (R).
For MODE: FT8, the LoTW, eQSL and ClubLog work well, and the LoTW (R), eQSL (R) and Clublog (R) fields, in to LogHX are correctly confirms;
However, for MODE: MFSK, SUBMODE: FT4, only Clublog can confirm the Clublog (R) field as OK.
From file download:
ClubLog dl: ... <MODE:3>FT4 ... > the Clublog(R) field confirms, as OK;
<MODE:3>FT8 ... > the Clublog(R) field confirms, as OK;
eQSL dl: ... <MODE:3>FT8 ... > the eQSL(R) field confirms, as OK;
<MODE:4>MFSK<SUBMODE:3>FT4 ... > the field eQSL(R), NOT confirms;
LoTW dl: ... <MODE:3>FT8 ... > the LoTW(R) field confirms, as OK;
<MODE:4>MFSK <SUBMODE:3>FT4 ... > the field LoTW(R) NOT confirms.
In the Setup LogHX , Mode Setup, I found the standard configurations as : Mode - FT4, ModeDXCC - DIGITAL, Report - (-10), and V as OK, SubMode - FT4, Mode - MFSK.
Thanks for any help, to setup the LogHX, and get the FT4, LoTW and eQSL confirmations.
Happy New Year!!
"Stay safe"
73 from py5ej,
Pavanatti.
05.01.2021, 01:28 #163Standart Power
- 03.01.2021
- 196
- 18
Hello Alde,
I donwload and receive confirm from EQSL and LOTW without problem.
You must verify that you have qso correct in the log.
You must have MODE MFSK and SUBMODE FT4
Sure you will have MODE FT4 ....wrong....
05.01.2021, 09:34 #164Координатор темы
- 03.02.2006
- 53
- 20,458
- 10078
- 5414
05.01.2021, 15:52 #165Standart Power
- 03.01.2021
- 196
- 18
Good morning,
in the calculation of the DXCC statistics, if I choose DXCC MODE,
it only presents me the choice of CW - DIGITAL - PHONE
the MIXED mode is missing.
Hope it will be fixed in the next version.
Thanks.
167Спасибо
