Цитата:
"SSL connect error" -"SSL connect error" (schannel: next InitializeSecurityContext failed: SEC_E_UNTRUSTED_ROOT (0x80090325) - The certificate chain was issued by an authority that is not trusted.)"
This is an MS Windows problem.
Should be an easy fix:
Download the latest root certificate update for XP from MS:
<http://www.microsoft.com/en-us/download/details.aspx?id=38918>
Then, to ensure that automatic root certificate updating is enabled in Windows XP:
Go to Control Panel, Add or Remove Programs.
Click Add/Remove Windows Components.
Check the box - Update Root Certificates
Ссылка в статье не рабочая, ниже рабочая на обновление корневых сертификатов для XP
