Страница 8 из 68 ПерваяПервая 1234567891011121314151858 ... ПоследняяПоследняя
Показано с 106 по 120 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #106
    07.04.2002
    г.Москва, г.Троицк
    48
    9,453
    2540
    7642
    Set name for new icon LogHX_Modile or other and run LogHX from new icon. Set QRZ.COM settings for /M call.
    Now you have two loghx icons - for home and for mobile.
    Ok, good
    But I have experience with this:
    - I made 1 LOG for some callsigns
    - my LOG I have databases for RC3C, RC3C/5 etc..
    - If I need to use RC3C/5 (for example)
    - I go to File -> Open New Log in database
    - choose RC3C/5 and click Open
    It's easy, Watson
  2. #107
    25.03.2020
    30
    3
    20
    Alexei,
    I use LogHX3 with SunSDR2-DX and Flex-6300 (not at the same time, however).
    Each radio has 2 CAT controlled Receivers, where I usually use RX2 (Radio2) for FT4/FT8 with JTDX (connected to LOGHX with UDP) and at the same time chasing CW DX using RX1 (Radio1).
    In this setup the RX2 (Radio2) with JTDX is not marked as the "active" Radio in LogHX3.
    The problem arises using the Active Calls window, where I cannot find any way to bind that to the radio that is "inactive" in LogHX, making the QSL status-colouring in the Active Calls Window follow the band on the active radio.
    E.g. when chasing DX on Radio1 on 15 meter band, and monitoring the FT8 activity on 20 meters, the Active Calls Window shows QSL status on FT8 related to the 15 meter band, and not the 20 meter band:
Название:	Active calls window - false status.PNG
    Have I overlooked something in he LogHX3 setup, enabling the Active Calls Window QSL status colouring to follow the "inactive" Radio?
    73 de LB2EG Richard
  3. #108
    03.02.2006
    20,259
    9959
    5328
    Ok! I'll make in new version: for Active Calls Window will be possible set Radio1 or Radio2 manually. Is this correct?
  4. #109
    25.03.2020
    30
    3
    20
    Yes. A choice of Radio1 or Radio2 in setup for Active calls window would be great!
    73 de LB2EG Richard
  5. #110
    25.03.2020
    30
    3
    20
    Alexei,
    this worked well until the last iteration of 589 prerelase of today. Now all spots are forwarded to the SmartSDR UDP-port...
    73 de LB2EG Richard
  6. #111
    Low Power
    16.04.2020
    88
    3
    Can you have a look if there is a bug around QRZ look ups stopping working if you operator over the change of day, ie 23:59>>>>00:00. I do this often and it seems to not fill in once you hit midnight and I have to restart the program.
  7. #112
  8. #113
  9. #114
    03.02.2006
    20,259
    9959
    5328
    I think - problem in QRZ.COM certificate - need renew it. I'll fix this.
    Started to get some leaks on closing a few times
    Version of log?
  10. #115
    Low Power
    16.04.2020
    88
    3
    580, I think it might have started when I installed the one for the mobile log. I couldn't get all that to work so maybe we now have a mix of data.
    Ian
  11. #116
    03.02.2006
    20,259
    9959
    5328
    580
    Install this version:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_589.exe
    here memory leaks is fixed.
    It's not good... I check problem.
    Setup->Time life spots->
    check it for only needed spots.
  12. #117
    25.03.2020
    30
    3
    20
    Alexei,
    mea culpa!
    I had overlooked the "show only colored spots" option. Works well.
    I am also very happy with the show only coloured spots options in Cluster window, Bandmap windows and Active calls window.
    I hope you will find time to make a choice between Radio1 and Radio2 in Active calls window.
    73 de LB2EG Richard
  13. #118
    03.02.2006
    20,259
    9959
    5328
    There is very little time for log - many coworkers is sick.
    But only for you -
    http://rx4hx.qrz.ru/files/loghx/prer..._build_590.exe
    now band in Active calls window will be from WSJT-X/JTDX. I think - it's right. Not need choice radio.
    Try this version.
  14. #119
    Low Power
    16.04.2020
    88
    3
    I am trying to get myrig and myant data to stay with each QSO, but I cannot get it to enter automatically on start like my profile callsign and Locator. I notice that entries from FT8 from UDP (gridtracker and wsjtx) have the myant and my rig data. So I think something is not right with my log set up.
  15. #120
    03.02.2006
    20,259
    9959
    5328
    You must use menu "Select Profile", not "Change operator". I just checked - insert from Profile worked well.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
