Страница 47 из 68 ПерваяПервая ... 3740414243444546474849505152535457 ... ПоследняяПоследняя
Показано с 691 по 705 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #691
    26.10.2019
    46
    17
    9
    After setting the administrator right, in the latest versions (734 and 735), everything works normally.
    Thanks for your help, 73 from py5ej.
  2. #692
    25.07.2023
    10
    Really easy this question I am sure. Which is the option to preview the image and other information from QRZ.com. I have closed it accidentally and just remember the name of the window to select.
    73 de Danny M0SDB
  3. #693
    25.07.2023
    10
    I have found it again - Right click on the QSO input window then 'Find...'/Find call on QRZ.com'
  4. #694
    07.07.2023
    16
    3
    3
    HamLib\Network Connected Radio Usage
    Alexei, I trust you're doing well.
    I've come across a question regarding the RADIO SETUP > RADIO 1 > HAMLIB > Setup in our beloved logbook. While exploring the menus, especially the radio control settings, I noticed a screen where we can configure RADIO 1 or 2. There's an option labeled "HAMLIB" specifically for setting up a "NETWORK CONNECTED RADIO." I'm curious about how this is supposed to function; does it relate to Hamlib TCP rig control daemon RIGCTLD?
    The question is the Radio Setup/HamLib/Network connected radio (PICTURE LEFT SIDE) the same thing as in JTDX HamLib NET Rigctl (PICTURE RIGHT SIDE)?
    For context, the rigctld program is a NEW Hamlib rig control daemon ready for testing that handles client requests via TCP sockets. This allows multiple user programs to share one radio.
    In my scenario I've successfully got my older radios (TS440S and IC718) running smoothly using RIGCTLD in conjunction with either JTDX/WSJT-X. Of course it took some time to figure out, but with a simple command line, I can switch the CAT Control between radios and control them seamlessly.
    Just as reference I'm sharing the batch file I'm currently using for Hamlib TCP rig control:
    Batch File for IC-718
    Код:
    @echo off
    del D:\Ham\HamLib\log.txt
    rem ----------------------------------------------------------------
    rem D:\Ham\HamLib\hamlib-w64-4.5.5\bin\rigctld.exe -m 3013 -r COM1 -s 9600 -c 0x5E --set-conf="dtr_state=ON" -p COM7 -P DTR
    rem -m 3013                     << Seleciona o modelo ICOM IC-718
    rem -r COM1                     << Porta COM a ser utilizada no CI-V
    rem -s 9600                     << Set serial speed to 9600 baud
    rem -c 0x5E                     << CI-V address to communicate with the rig
    rem --set-conf="dtr_state=ON"   << ON turns on DTR, OFF turns it off, Unset disables it
    rem -t 4533                     << Change the termination network port for text protocol when using the
    rem -p COM7                     << Use as the file name of the Push-To-Talk device using a device file
    rem -P DTR                      << Use of Push-To-Talk device
    rem -vv                         << Set verbose mode, cumulative upt to 4 Vs
    rem -L                          << List all config parameters for the radio defined with
    rem -Z                          << Enable time stamps for the debug messages
    D:\Ham\HamLib\hamlib-w64-4.5.5\bin\rigctld.exe -m 3013 -r COM1 -s 9600 -c 0x5E --set-conf="dtr_state=ON" --set-conf="ptt_share=1" -t 4533 -p COM7 -P DTR -vv -Z -L >> D:\Ham\HamLib\log.txt
    I create a batch file and use the NSSM (Non-Sucking Service Manager) to create it as a Windows Service so I can launch it with windows Initialization
    I'd appreciate any insights or guidance you can provide on the HAMLIB option in the logbook setup.
  5. #695
    21.07.2022
    80
    20
    How to add new band?
    Hello,
    I cannot to add 70 MHz (4m) band to General Setup (OLEdB error). Can you help?
    73 Josef OK2WO
  6. #696
    03.02.2006
    20,683
    10187
    5465
    Right mouse click - "Reset Bandplan". Problem will be solved.
    Цитата Сообщение от PY5XT Посмотреть сообщение
    HAMLIB
    Please wait! I need to study the information.
  7. #697
    21.07.2021
    Рассказово
    51
    12
    6
    Здравствуйте! Появилась такая проблема, на данный момент работает версия 732, в новых релизах программы (по 737) перестала корректно закрываться программа sdruno, которая запускается одновременно с Loghx3 через установки для внешних программ. Подскажите, пожалуйста, в чем может быть дело и как исправить, до 732 версии все было хорошо.
  8. #698
    03.02.2006
    20,683
    10187
    5465
    Причину знаю, завтра постараюсь исправить.
    ... И давайте в русскоговорящую ветку перейдем!
  9. #699
    07.07.2023
    16
    3
    3
    Hey Alexei,
    I wanted to share some additional information about using Hamlib Net now with FLDIGI, and you can check out the attachment for more details.
    For instance, I've successfully run JTDX, WSJT-X, and FLDIGI simultaneously, with all programs having access to RADIO CAT. It's worth noting that this might not be feasible with every program open at the same time, but in certain contexts, it's definitely doable.
    Feel free to explore and let me know if you have any questions!
  10. #700
    03.01.2021
    196
    18
    » UTILITIES -> FIND MANAGER (NOT INSERT MANAGER)
    NOT WORK with "CURRENT QSO"
    NOT WORK with "ALL QSO"
    NOT WORK with "SELECTED QSO"
    Please Alexei verify, this work only, if find a single manager,
    but if find a multiple manager, for example, with different year,
    the utilities don't insert the manager, they move on (skip), it should insert the most recent one instead
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  11. #701
    03.02.2006
    20,683
    10187
    5465
    Must be fixed, please check -
    https://forum.qrz.ru/355-loghx-appar...ml#post1988066
  12. #702
    03.01.2021
    196
    18
    Unfortunately it doesn't work,
    it inserts the manager only if it finds a single result,
    if it finds multiple managers with different years,
    it does not insert anything, skips the QSO and moves on to the next one.
    In this case it should choose the one with the most recent date, and insert it.
    Thanks.
    73 de IK2XDE Andrea
  13. #703
    Low Power
    02.05.2021
    6
    Код:
    @echo off
    Hello Eleandro and Alexei,
    Thanks very much for Hamlib explanations. It is very usefull.
    73s Christian F8GHE
  14. #704
    03.02.2006
    20,683
    10187
    5465
    Yes. If for station found only one manager - insert anyway.
    If found many managers - check date interval. If not found valid date interval - manager is not set.
    ... Well, as variant:
    first - check for valid begin and end date
    if not found - check for valid begin or end date
    if not found again - insert last manager.
  15. #705
    03.01.2021
    196
    18
    Yes I think this is the best solutions.
    It will work correct.
    Please verify also manual insert, I just send you a video of the problem,
    when we push insert, DO NOT CHECK the call of qso.....so insert a manager
    to any qso without verify the call.
    Thanks.
    Wait for new prerelease.
    73 de IK2XDE Andrea
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
