15.09.2023, 15:44 #691
- 26.10.2019
- 46
- 17
- 9
After setting the administrator right, in the latest versions (734 and 735), everything works normally.
Thanks for your help, 73 from py5ej.
19.09.2023, 21:06 #692
- 25.07.2023
- 10
Really easy this question I am sure. Which is the option to preview the image and other information from QRZ.com. I have closed it accidentally and just remember the name of the window to select.
73 de Danny M0SDB
23.09.2023, 15:50 #693
- 25.07.2023
- 10
I have found it again - Right click on the QSO input window then 'Find...'/Find call on QRZ.com'
27.09.2023, 20:22 #694
- 07.07.2023
- 16
HamLib\Network Connected Radio Usage
Alexei, I trust you're doing well.
I've come across a question regarding the RADIO SETUP > RADIO 1 > HAMLIB > Setup in our beloved logbook. While exploring the menus, especially the radio control settings, I noticed a screen where we can configure RADIO 1 or 2. There's an option labeled "HAMLIB" specifically for setting up a "NETWORK CONNECTED RADIO." I'm curious about how this is supposed to function; does it relate to Hamlib TCP rig control daemon RIGCTLD?
The question is the Radio Setup/HamLib/Network connected radio (PICTURE LEFT SIDE) the same thing as in JTDX HamLib NET Rigctl (PICTURE RIGHT SIDE)?
For context, the rigctld program is a NEW Hamlib rig control daemon ready for testing that handles client requests via TCP sockets. This allows multiple user programs to share one radio.
In my scenario I've successfully got my older radios (TS440S and IC718) running smoothly using RIGCTLD in conjunction with either JTDX/WSJT-X. Of course it took some time to figure out, but with a simple command line, I can switch the CAT Control between radios and control them seamlessly.
Just as reference I'm sharing the batch file I'm currently using for Hamlib TCP rig control:
Batch File for IC-718
Код:@echo off del D:\Ham\HamLib\log.txt rem ---------------------------------------------------------------- rem D:\Ham\HamLib\hamlib-w64-4.5.5\bin\rigctld.exe -m 3013 -r COM1 -s 9600 -c 0x5E --set-conf="dtr_state=ON" -p COM7 -P DTR rem ---------------------------------------------------------------- rem -m 3013 << Seleciona o modelo ICOM IC-718 rem -r COM1 << Porta COM a ser utilizada no CI-V rem -s 9600 << Set serial speed to 9600 baud rem -c 0x5E << CI-V address to communicate with the rig rem --set-conf="dtr_state=ON" << ON turns on DTR, OFF turns it off, Unset disables it rem -t 4533 << Change the termination network port for text protocol when using the rem -p COM7 << Use as the file name of the Push-To-Talk device using a device file rem -P DTR << Use of Push-To-Talk device rem -vv << Set verbose mode, cumulative upt to 4 Vs rem -L << List all config parameters for the radio defined with rem -Z << Enable time stamps for the debug messages rem ---------------------------------------------------------------- D:\Ham\HamLib\hamlib-w64-4.5.5\bin\rigctld.exe -m 3013 -r COM1 -s 9600 -c 0x5E --set-conf="dtr_state=ON" --set-conf="ptt_share=1" -t 4533 -p COM7 -P DTR -vv -Z -L >> D:\Ham\HamLib\log.txt
I'd appreciate any insights or guidance you can provide on the HAMLIB option in the logbook setup.
28.09.2023, 17:53 #695
- 21.07.2022
- 79
- 16
How to add new band?
Hello,
I cannot to add 70 MHz (4m) band to General Setup (OLEdB error). Can you help?
73 Josef OK2WO
28.09.2023, 18:30 #696
- 03.02.2006
- 19,291
- 9362
- 4982
Ant.: UW4HW, Pwr.: ~500 Wtts
28.09.2023, 19:16 #697
- 21.07.2021
- Рассказово
- 5
Здравствуйте! Появилась такая проблема, на данный момент работает версия 732, в новых релизах программы (по 737) перестала корректно закрываться программа sdruno, которая запускается одновременно с Loghx3 через установки для внешних программ. Подскажите, пожалуйста, в чем может быть дело и как исправить, до 732 версии все было хорошо.
28.09.2023, 19:36 #698
- 03.02.2006
- 19,291
- 9362
- 4982
07.10.2023, 15:49 #699
- 07.07.2023
- 16
Hey Alexei,
I wanted to share some additional information about using Hamlib Net now with FLDIGI, and you can check out the attachment for more details.
For instance, I've successfully run JTDX, WSJT-X, and FLDIGI simultaneously, with all programs having access to RADIO CAT. It's worth noting that this might not be feasible with every program open at the same time, but in certain contexts, it's definitely doable.
Feel free to explore and let me know if you have any questions!
20.10.2023, 21:44 #700
- 03.01.2021
- 53
- 182
- 18
» UTILITIES -> FIND MANAGER (NOT INSERT MANAGER)
NOT WORK with "CURRENT QSO"
NOT WORK with "ALL QSO"
NOT WORK with "SELECTED QSO"
Please Alexei verify, this work only, if find a single manager,
but if find a multiple manager, for example, with different year,
the utilities don't insert the manager, they move on (skip), it should insert the most recent one instead
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 20/02/2019)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 Mhz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
20.10.2023, 22:37 #701
- 03.02.2006
- 19,291
- 9362
- 4982
Must be fixed, please check -
https://forum.qrz.ru/355-loghx-appar...ml#post198806673 de RX4HX, Alexei, http://rx4hx.qrz.ru
21.10.2023, 14:30 #702
- 03.01.2021
- 53
- 182
- 18
Unfortunately it doesn't work,
it inserts the manager only if it finds a single result,
if it finds multiple managers with different years,
it does not insert anything, skips the QSO and moves on to the next one.
In this case it should choose the one with the most recent date, and insert it.
Thanks.
21.10.2023, 17:46 #703
- 02.05.2021
- 51
- 6
23.10.2023, 13:46 #704
- 03.02.2006
- 19,291
- 9362
- 4982
Yes. If for station found only one manager - insert anyway.
If found many managers - check date interval. If not found valid date interval - manager is not set.
... Well, as variant:
first - check for valid begin and end date
if not found - check for valid begin or end date
if not found again - insert last manager.Последний раз редактировалось RX4HX; 23.10.2023 в 14:00.
23.10.2023, 19:28 #705
- 03.01.2021
- 53
- 182
- 18
Yes I think this is the best solutions.
It will work correct.
Please verify also manual insert, I just send you a video of the problem,
when we push insert, DO NOT CHECK the call of qso.....so insert a manager
to any qso without verify the call.
Thanks.
Wait for new prerelease.
