Tnx Christo I know this and usually also don’t look what is in eesdr tci log, vice versa if this log is open then after few minutes tci will slow down until crash.
HI Arvo
Для вас если хочиш ползаватса, дайу мой TCI echo server
здесь https://drive.google.com/drive/folde...F8C6MmQjcHQS_s
фаил TCI_HV.zip
С етот сервер сможеш сматрет свой сигнал (JTDX), Вы можете использовать MSHV (MSHV_WIN64_2762_rc003.zip) в качестве монитора.
MSHV_WIN64_2762_rc003.zip автоматически распознавать все параметры сигнала и показывает на водопад
bit per sample (16,24,32,float32), sample rate, channels, buffers
Вход на 127.0.0.1:50001
Простo старта TCI_HV.exe, MSHV, JTDX, connect TCI Client RX1 and see all what is happens
Tnx, but usually I even don’t have win computer, just virtual under linux. But never knows.
OK Arvo
У меня нет проблем с компиляцией TCI_HV для Linux
Но если вам не интересно тестировать, ok
Я удаляю с Google Drive
Вопрос к LZ2HV или ES1JA: есть ли инструкция как через TCI можно передать WAV-файл? Нужно для передачи SSB макросов через TCI. У разработчиков ESDR что-то толком ничего выяснить не удалось.
Through TCI audio can be sent only as audio stream, but is possible to write client program that sends stream from wav.
You can look in src of jtdx or mshv what needed in client for audio stream, also at least some cat commands needed to implement, (setting tx). Now when You selecting wav for tx-ng then after enabling tx tci will ask to begin stream changing audio stream type to TxChrono, now you will stream until file end and then take off tx. PS is recommended to have wav-s in audio format directly supported by tci.
About vfo if and dds commands, You were correct and I done band change to simple, as it worked for me, don’t tested with many versions of eesdr. Now will use on band change dds and if commands instead of vfo and recently added if. Within band and for vfo 1 all time vfo command is used. So tnx for pointing this problem out.
Вы можете посмотреть в src jtdx или mshv, что нужно клиенту для аудиопотока, а также, по крайней мере, некоторые команды cat, необходимые для реализации (настройка tx). Теперь, когда вы выбираете wav для tx-ng, то после включения tx tci попросит начать поток, изменив тип аудиопотока на TxChrono, теперь вы будете транслировать до конца файла, а затем отключите tx. P.S. Рекомендуется иметь wav-s в аудиоформате, напрямую поддерживаемом tci.
О командах vfo if и dds, вы были правы, и я сделал смену полосы на простую, так как это сработало для меня, не тестировалось со многими версиями eesdr. Теперь буду использовать команды смены полосы dds и if вместо vfo и недавно добавленных if. В пределах полосы и для vfo 1 все время используется команда vfo. Так что спасибо за указание на эту проблему.
....Через loghx запускаю rc3 - всё нормально работает , пробую новую rc8 - не срабатывает "АВТОВЫБОР" или срабатывает с большим опозданием ...настройки и там и там одинаковые , приходиться в ручную отвечать постоянно....Может в новой версии какая то ещё настройкв нужна ?!?...
Вложение 366647Вложение 366648
Lag 8 sec.
RX4HX, do You get email?
Strange, sent again from my other address.
159 has tci. Look once again.
...попробовал удалил , заново установил - не помогло , срабатывает с большой задержкой...пришлось остаться на RC3....
