Сообщение от
ES1JA
General rule, -26 decodes should be rare if not to say very rare. It depends mainly of qrm situation in qth. 1. To try is set QSO Rx freq sensitivity to low. If remember correctly medium is default there. It is normal for good qth qrm cases. In city environment often needed to but low there. Vice versa I can use with TCI and sunsdr2dx high there, despite living in Tallinn. ( ok I have relative quiet environment here). With FT-847 I can’t use high, to much -25 -26 decodes, but can use medium. Same environment same antennas, so there many aspects. Everyone should find own solution. Also needed to find out best audio input level.
Everyone should find best decoder settings for own environment. There 2 aspects, computer power and qrm.
I agree that getting “wrong” decodes is wired, but always need to decide, which is better is to get sometimes wrong decode or not get decodes at all.
