TCI received - это то, что я получаю от MSHV
TCI sent - то, что я отправляю MSHV
Код:
[2025/04/04 09:42:54.6317] INFO Net/TCI.c:986: TCI connection request from 192.168.0.11
[2025/04/04 09:42:54.6319] TRACE Net/TCI.c:1026: TCI sent 'vfo_limits:10000,54000000;' to 192.168.0.11
[2025/04/04 09:42:54.6320] TRACE Net/TCI.c:1026: TCI sent 'if_limits:0,0;' to 192.168.0.11
[2025/04/04 09:42:54.6321] TRACE Net/TCI.c:1026: TCI sent 'trx_count:2;' to 192.168.0.11
[2025/04/04 09:42:54.6322] TRACE Net/TCI.c:1026: TCI sent 'channel_count:1;' to 192.168.0.11
[2025/04/04 09:42:54.6323] TRACE Net/TCI.c:1026: TCI sent 'device:Neon3;' to 192.168.0.11
[2025/04/04 09:42:54.6324] TRACE Net/TCI.c:1026: TCI sent 'protocol:Neon3,1.9;' to 192.168.0.11
[2025/04/04 09:42:54.6325] TRACE Net/TCI.c:1026: TCI sent 'receive_only:false;' to 192.168.0.11
[2025/04/04 09:42:54.6326] TRACE Net/TCI.c:1026: TCI sent 'modulations_list:am,sam,lsb,usb,cw,cwu,nfm,digl,digu,rtty,psk31;' to 192.168.0.11
[2025/04/04 09:42:54.6327] TRACE Net/TCI.c:1026: TCI sent 'start;' to 192.168.0.11
[2025/04/04 09:42:54.6328] TRACE Net/TCI.c:1026: TCI sent 'vfo:0,0,14074000;' to 192.168.0.11
[2025/04/04 09:42:54.6328] TRACE Net/TCI.c:1026: TCI sent 'vfo:1,0,14070000;' to 192.168.0.11
[2025/04/04 09:42:54.6329] TRACE Net/TCI.c:1026: TCI sent 'dds:0,14074000;' to 192.168.0.11
[2025/04/04 09:42:54.6330] TRACE Net/TCI.c:1026: TCI sent 'dds:1,14070000;' to 192.168.0.11
[2025/04/04 09:42:54.6330] TRACE Net/TCI.c:1026: TCI sent 'if:0,0,0;' to 192.168.0.11
[2025/04/04 09:42:54.6331] TRACE Net/TCI.c:1026: TCI sent 'if:1,0,0;' to 192.168.0.11
[2025/04/04 09:42:54.6332] TRACE Net/TCI.c:1026: TCI sent 'modulation:0,digu;' to 192.168.0.11
[2025/04/04 09:42:54.6332] TRACE Net/TCI.c:1026: TCI sent 'modulation:1,digu;' to 192.168.0.11
[2025/04/04 09:42:54.6333] TRACE Net/TCI.c:1026: TCI sent 'split_enable:0,false;' to 192.168.0.11
[2025/04/04 09:42:54.6334] TRACE Net/TCI.c:1026: TCI sent 'split_enable:1,true;' to 192.168.0.11
[2025/04/04 09:42:54.6335] TRACE Net/TCI.c:1026: TCI sent 'rx_channel_enable:0,0,true;' to 192.168.0.11
[2025/04/04 09:42:54.6335] TRACE Net/TCI.c:1026: TCI sent 'rx_channel_enable:1,0,false;' to 192.168.0.11
[2025/04/04 09:42:54.6336] TRACE Net/TCI.c:1026: TCI sent 'rx_filter_band:0,300,2800;' to 192.168.0.11
[2025/04/04 09:42:54.6336] TRACE Net/TCI.c:1026: TCI sent 'rx_filter_band:1,300,2700;' to 192.168.0.11
[2025/04/04 09:42:54.6337] TRACE Net/TCI.c:1026: TCI sent 'volume;' to 192.168.0.11
[2025/04/04 09:42:54.6338] TRACE Net/TCI.c:1026: TCI sent 'rx_volume:0,0,0;' to 192.168.0.11
[2025/04/04 09:42:54.6339] TRACE Net/TCI.c:1026: TCI sent 'rx_volume:1,0,-20;' to 192.168.0.11
[2025/04/04 09:42:54.6339] TRACE Net/TCI.c:1026: TCI sent 'mute;' to 192.168.0.11
[2025/04/04 09:42:54.6341] TRACE Net/TCI.c:1026: TCI sent 'rx_mute:0,true;' to 192.168.0.11
[2025/04/04 09:42:54.6342] TRACE Net/TCI.c:1026: TCI sent 'rx_mute:1,true;' to 192.168.0.11
[2025/04/04 09:42:54.6344] TRACE Net/TCI.c:1026: TCI sent 'rx_balance:0,0,-10;' to 192.168.0.11
[2025/04/04 09:42:54.6345] TRACE Net/TCI.c:1026: TCI sent 'rx_balance:1,0,10;' to 192.168.0.11
[2025/04/04 09:42:54.6346] TRACE Net/TCI.c:1026: TCI sent 'trx:0,false;' to 192.168.0.11
[2025/04/04 09:42:54.6347] TRACE Net/TCI.c:1026: TCI sent 'ready;' to 192.168.0.11
[2025/04/04 09:42:55.1389] TRACE Net/TCI.c:1040: TCI received (8) 'vfo:0,0;' from 192.168.0.11
[2025/04/04 09:42:55.1391] TRACE Net/TCI.c:1026: TCI sent 'vfo:0,0,14074000;' to 192.168.0.11
[2025/04/04 09:42:55.1513] TRACE Net/TCI.c:1040: TCI received (23) 'audio_samplerate:12000;' from 192.168.0.11
[2025/04/04 09:42:55.1514] TRACE Net/TCI.c:1040: TCI received (33) 'audio_stream_sample_type:float32;' from 192.168.0.11
[2025/04/04 09:42:55.1515] TRACE Net/TCI.c:1040: TCI received (24) 'audio_stream_channels:1;' from 192.168.0.11
[2025/04/04 09:42:55.1515] TRACE Net/TCI.c:1040: TCI received (26) 'audio_stream_samples:2048;' from 192.168.0.11
[2025/04/04 09:42:55.1516] TRACE Net/TCI.c:1040: TCI received (29) 'tx_stream_audio_buffering:50;' from 192.168.0.11
[2025/04/04 09:42:55.1516] TRACE Net/TCI.c:1040: TCI received (14) 'audio_start:0;' from 192.168.0.11
[2025/04/04 09:42:55.1517] TRACE Net/TCI.c:1040: TCI received (17) 'tx_enable:0,true;' from 192.168.0.11
[2025/04/04 09:42:55.1517] TRACE Net/TCI.c:1040: TCI received (17) 'rx_enable:0,true;' from 192.168.0.11
[2025/04/04 09:42:55.1518] TRACE Net/TCI.c:1040: TCI received (16) 'rx_mute:0,false;' from 192.168.0.11
[2025/04/04 09:42:56.1367] TRACE Net/TCI.c:1040: TCI received (13) 'modulation:0;' from 192.168.0.11
[2025/04/04 09:42:56.1368] TRACE Net/TCI.c:1026: TCI sent 'modulation:0,digu;' to 192.168.0.11
[2025/04/04 09:42:57.1541] TRACE Net/TCI.c:1040: TCI received (8) 'vfo:0,0;' from 192.168.0.11
[2025/04/04 09:42:57.1542] TRACE Net/TCI.c:1026: TCI sent 'vfo:0,0,14074000;' to 192.168.0.11
[2025/04/04 09:42:58.1541] TRACE Net/TCI.c:1040: TCI received (13) 'modulation:0;' from 192.168.0.11
[2025/04/04 09:42:58.1542] TRACE Net/TCI.c:1026: TCI sent 'modulation:0,digu;' to 192.168.0.11
[2025/04/04 09:42:59.1404] TRACE Net/TCI.c:1040: TCI received (8) 'vfo:0,0;' from 192.168.0.11
[2025/04/04 09:42:59.1406] TRACE Net/TCI.c:1026: TCI sent 'vfo:0,0,14074000;' to 192.168.0.11
