И сделайте архивы логов и настроек на другой диск, и делайте их регулярно. 2 крайние кнопки на панели инструментов логгера.
aaaaa, мы победили :)
Hi all,
The NEXT release of Logger32 will contain a very comprehensive set of user
options for automatic backup. These are currently under test as we speak.
73 de Geoff
G3NPA
Geoff.Anderson@btinternet.com
----- Original Message -----
To: <hamlogger@yahoogroups.com>
Sent: Friday, November 26, 2010 9:06 PM
Subject: [hamlogger] Re: automatic back-ups feature request
I see no need for an automatic batch program to zip files as part of L32.
Windows already has that - taskmgr.
Gerald Boutin, VE1DT
--- In hamlogger@yahoogroups.com, "Art" <rx99tx@...> wrote:
> I think you miss my point too. They already provide such a capability, I
> thought I was clear on what I want, that is automatic creation of zipped
> log archives on a user-defined schedule. The rest is done by free cloud
> services.
> --- In hamlogger@yahoogroups.com, k4cy@ wrote:
> > I think you miss my point. If someone wants to develop/sell a
> > commercial backup/archive product, don't you think they should/would
> > provide the capability for a user defined automatic (alarm clock based)
> > mechanism to upload the file(s) of choice? I think you're looking in
> > the wrong direction
> > 73,
> > From: Art R8TX <rx99tx@>
> > To: k4cy@ <hamlogger@yahoogroups.com>
> > Sent: Thu, 25 Nov 2010 02:14:29 -0000 (UTC)
> > Subject: Re: [hamlogger] automatic back-ups feature request
> > Nobody is perfect, even you Bob. Is it that hard to implement, bet
> > that would save a lot of users logs and nerves.
> > k4cy@ wrote:
> > kcn> Yet another programming proverb: Bad planning on your part does
> > kcn> not constitute an emergency on my part
> > kcn> 73,
> > > To: hamlogger@yahoogroups.com
> > > Sent: Wed, 24 Nov 2010 18:49:52 -0000 (UTC)
> > > Subject: [hamlogger] automatic back-ups feature request
> > > Hello ,
> > > I use www.sugarsync.com for backing up the data I do not want to
> > > lose, logs included. The program syncs the files automatically when
> > > any change to a file in a defined folder has been made.
> > > The feature request is to teach the logger to make the back-ups
> > > automatically on the user-defined schedule, say once a day, so the
> > > entire back-up process could be made invisible and silent.
> > R8TX (ex RX9TX)
> > http://r8tx.qrz.ru
> > "We give nothing so freely as advice." [Francois de la Rochefoucauld]
Доброе время суток уважаемые коллеги!
Извините за тупость и незнание:sorry: - но подскажите как у лога ведутся менеджеры!
Как и откуда их импортировать!
Виктор
Есть поле QSL VIA, но кажеться его надо заполнять для каждое QSO вручную.
На панели инструментов Logger32 пятая справа кнопка Internet Callsign Lookup после нажатия открывается окно в котором есть пункт Transfer, в котором можно выбрать, что будет автоматически переноситься с QRZ.COM в журнал (в интересующем Вас случае надо выбрать Transfer QSL VIA). Если нет подключения к интернету можно использовать Callbook на CD (третья справа кнопка панели инструментов).
Просьба, подскажите где взять русификатор, может в теме и было, но 79 страниц листать тяжко.
Сам нашел:
http://www.logger32.net/support.html
Друзья, вот такой возник вопрос (продолжаю разбираться с Logger32 после DX4WIN-а). Как бы сделать, чтобы когда заношу QSO в журнал (функция Добавить QSO), нажимать ENTER, как в DX4WIN-е, чтобы оно заносилось, а не тыкать мышкой на ADD QSO, как сейчас я делаю? Или это в принципе невозможно?
Дмитрий!
Вы имеете в виду занесение QSO с помощью CTRL+M ?
Да, Николай! Именно его!
Я пользуюсь этой опцией достаточно редко, для занесения единичных QSO. Например, работаю в контесте с N1MM и наткнулся на интересного DXа, который в соревнованиях не участвует (вчера, к примеру, во время 9А-теста набрел на VK9), записываю связь на листке, а затем (после контеста) Logger32 - Ctrl+M. Если речь идет о вводе значительного количества связей, то, на мой взгляд, более рационально сделать ADIF (с помощью, например, Fast Log Entry от DF3CB http://dfcb.com/fle/index.html ) и быстро, без проблем его импортировать в Logger32.
Ну вот... Это же (Fast Log Entry от DF3CB), только по поводу проги DXLab мне предложил UA6JD - оказалось, что в DXLab тоже нет этой функции. Жаль, что сказать! Спасибо, Николай! :-)
Из своего опыта: аналогичная ситуация. Только в новом качестве: после установки VSPE (Виртуальный последовательный порт эмулятор) работаю сразу двумя, а то и тремя логами N1MM, Loggth32, HRD. Набрел на интересного корр-та, переключился в L32, сработал с записью в журнал - и обратно в тестовую среду... :victory:
VSPE я тоже использую, но такой вариант мне не приходил в голову. Спасибо за подсказку.
