Появилось интерсное обновление для IC-7300/7850/7851
Интресно, а для 7600 его можно "приделать", если использовать вот эту переделку http://www.ab4oj.com/icom/ic7600/ic7600_rtl_sdr.pdf
N1MM Logger Website | Icom Spectrum Display
Supported are:
CW signal detection - the program finds the signals - if this doesn't strike you as important, you will be underwhelmed
Jumping from signal to signal using Shift+Up/Down
Vertical & horizontal spectrum display with spots shown
Static filter
Snap to signal
User settable noise floor
Click to set rx & tx frequencies
Signal filtration based on spot type - workable, self spots
This is a work in progress, but we are very pleased with the results. The code is finding signals quite reliably and at this point even has a setting where you can display just unspotted signals - something an assisted or a multi-op contest station would want.
