Страница 9 из 68 ПерваяПервая ... 23456789101112131415161959 ... ПоследняяПоследняя
Показано с 121 по 135 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #121
    Low Power
    16.04.2020
    88
    3
    This is my Profile that I am using. Still nothing appears. It was already using this profile, I haven't changed it since posting.
    I cleared my profile.ini
    it now looks like this
    ; Created at 21/11/20 16:18
    [M0CGF]
    Antenna=ZS6BKW
    Call=M0CGF
    County=
    IOTA=
    Locator=IO91WI
    Name=Ian
    Power=
    QTH=Sanderstead, South London
    SelfView=False
    State=
    Trcvr=IC-7300
    UseGPS=False
    User1=PSE QSL, Direct, Buro, LoTW, QRZ, Clublog, EQSL
    User2=
    User3=
    WFF=
  2. #122
    03.02.2006
    20,430
    10038
    5400
    Цитата Сообщение от M0CGF Посмотреть сообщение
    I am trying to get myrig and myant data to stay with each QSO
    Ok! I'm understand you problem: data from Profile will be inserted in log, when QSO saved, but not inserted in QSOEntry window for fields MyRig, MyAnt etc. It's right?
    I'll think of a better way to do it.
  3. #123
    Low Power
    16.04.2020
    88
    3
    Actually it does not go in to the log also.
    See the yellow highlights. The QSO's at the top I groupchanged the field before.
  4. #124
    03.02.2006
    20,430
    10038
    5400
    Try this version:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_593.exe
    Is now ok?
  5. #125
    Low Power
    16.04.2020
    88
    3
    now it writes the new info but now doesn't log mylocator Нажмите на изображение для увеличения.
    also doesn't autofill from qrz anymore
Размер: 40.2 Кбaccess error also on start. reloaded v589.
  6. #126
    07.04.2002
    г.Москва, г.Троицк
    48
    9,477
    2567
    7672
    Check this
    Последний раз редактировалось RC3C; 24.11.2020 в 02:59.
    73! Anton RC3C (ex.RV3DHC, RK3KPE, 5ØVE/Ø) & RY3AAL & 5ØRDXØØ3 & RK5AØØ2SWL & 5ØRC/38A2
  7. #127
    Low Power
    16.04.2020
    88
    3
    Thanks, I checked those setting and I have qrz.com ticked already.
  8. #128
    03.02.2006
    20,430
    10038
    5400
    Fixed:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_594.exe
  9. #129
  10. #130
    26.10.2019
    46
    17
    9
    Hello,
    LoTW Users.
    How to setup the logHX, v.3.0 build 595, to retrieve LoTW confirmations (CFM QSO).
    The program works well with e-QSL and Club Log, but I can't with LoTW, as explain the image to VE6 QSO:
Название:	LogHX and LoTW.jpg
    Thanks for any help,
    73 de py5ej,
    Pavanatti.
  11. #131
    03.02.2006
    20,430
    10038
    5400
    Do you setup LoTW login/password in LogHX?
    Is any data downloaded from LoTW server? Look at Download folder, file - LoTWdl.adi
  12. #132
    26.10.2019
    46
    17
    9
    Hello,
    Alexei.
    To abandon the UR5 log, I am trying work only with LogHX.
    Everything looks good, I can upload to LoTW, eQSL, ClubLog.
    The problem is with QSL-CFM in the LoTW.
    In the past, with UR5, I used the Oleg App (US-E-12) to do this job.
    I did a double check login/password in LogHX, I think it is all OK, can did the upload to LoTW.
    I don't find the file LoTWdl.adi.
    To check, after did the upload to LoTW, e-QSL, and ClubLog, see image an exemple, the QSO in my log, uploaded to LoTW, and confirmation QSL (W0AQ).
Название:	LogHX LoTW error 02.png
    Thanks for your attention, 73 de py5ej,
    Pavanatti.
  13. #133
    03.02.2006
    20,430
    10038
    5400
    Main window - Utilites - Correct log - Correct time: round to seconds
    Select it for all QSO and try again download and synchronize QSO's from LoTW.
    Now is Ok or not?
  14. #134
    26.10.2019
    46
    17
    9
    Hello Alexei,
    I did step by step the sugestion, but not work.
    When download and synchronize, is possible see:
Название:	LogHX LoTW error 04.png
    Maybe is an error file, but I can not find the file.
    Thanks for your attention.
    73 de py5ej,
    Pavanatti.
  15. #135
    26.10.2019
    46
    17
    9
    Hello Alexei,
    Hello Alexei,
    In order to get more information about LoTW QSO-CFM, I did a download without synchronize to the file LoTWdl.adi, it is annexed as LoTWdl.txt.
    As you can see is a file.html, to do Log on to Logbook of the World
    I inform you that the 4 fields referring to LoTW are configured in LogHX
    In case of the new one, where are setting?
    73 de py5ej,
    Pavanatti.
    Вложения Вложения
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
