23.07.2022, 13:29 #511
- 21.07.2022
- 78
- 7
Thank you
Super. All is clear. It works perfectly. Thank you for the help - I did not find it on online help pages. 73 GL Josef OK2WO
23.07.2022, 23:51 #512
- 21.07.2022
- 78
- 7
Hello,
I found by chance in the Forum new Macros for CW/Digital: [RX: <DOAFTERRX>]
<DOAFTERRX> - Letter:
S - SAVE, C - Clear TX Window, F- Focus to QSOentry window.
Macros Example: [RX: SCF], [RX: S], [RX: SC]
Question: Why is it not listed optionally in "Rig Control" menu?
73 Josef OK2WO
24.07.2022, 00:00 #513
- 03.02.2006
- 51
- 17,253
- 8059
- 4230
Ant.: UW4HW, Pwr.: ~500 Wtts
24.07.2022, 21:27 #514
- 02.05.2021
- 51
- 6
Hamlib Error during RADIO1 setup
I would like to use Hamlib for the setup of my Radio ICOM IC-705 but :
1. When I select Hamlib on the Radio Setup, I received this Error message : "Error Start Hamlib"
2. In the Hamlib setup the IC-705 is missing in the list
3. Hamlib files in the folder Hamlib seem very old (2014). How to update them ?
I tried to installed the last version Hamlib 4.4 but it is the same.
This setuo is not clear for me
73s Christian F8GHEПоследний раз редактировалось F8GHE; 24.07.2022 в 21:33.
24.07.2022, 23:02 #515
- 25.03.2020
- 30
- 20
Hi Christian, I have installed a new Hamlib on PC and thereafter copied the files to the Hamlib subdirectory under LogHX. Works, but I still get the Hamlib error message on LogHX start up. Choosing Hamlib from the radio drop down menu makes it all work, though.
73 de LB2EG Richard
25.07.2022, 01:42 #516
- 03.02.2006
- 51
- 17,253
- 8059
- 4230
Download files from here -
https://github.com/Hamlib/Hamlib/releases/tag/4.4
hamlib-w32-4.4.zip - for WIndows 32
hamlib-w64-4.4.zip - for WIndows 64
Here is test release of LogHX with new Hamlib 4.4:
http://rx4hx.qrz.ru/files/loghx/test..._build_699.exe
Hamlib check trx connection! Turn on trx before log run! And if you use IC-705, you must select IC-705 only, otherwise there will be an error! Now IC-705 present:
25.07.2022, 19:42 #517
- 02.05.2021
- 51
- 6
Hi Alexei and Richard,
Thanks very much for your help. Now LogHX is ready with Hamlib 4.4 and I'm able to select IC-705 !
73's Christian F8GHE
- - - Updated - - -
- - - Updated - - -
Hi Richard, Thanks very much. Now all is OK with the last LogHX build 699. Last Hamlib 4.4 is inside LogHX
73s Christian F8GHE
26.07.2022, 12:47 #518
- 21.07.2022
- 78
- 7
Sri does not work for me: vers. 699, FT-991 connected (works OK with Omnirig with the same settings). Still "Error start hamlib" - any idea? 73 Josef OK2WO
26.07.2022, 22:08 #519
- 03.02.2006
- 51
- 17,253
- 8059
- 4230
01.08.2022, 00:51 #520
- 16.04.2020
- 64
I have just updated to 700 and I am getting 2 entries into the log when I press enter. One entry has all the details from qrz, the other is a new line with just the callsign,date and time.
When I try and delete, it asks to update the dxcc statistics, then it creates another qso line.
01.08.2022, 09:49 #521
- 03.02.2006
- 51
- 17,253
- 8059
- 4230
01.08.2022, 11:00 #522
- 16.04.2020
- 64
thanks the issue is why is it adding 2 qso's then ont deleting them without adding another back in? i reverted to an older release now and its not happening.
02.08.2022, 00:46 #523
- 03.02.2006
- 51
- 17,253
- 8059
- 4230
30.08.2022, 12:31 #524
- 15.04.2021
- 78
- 12
LogHX + MSHV + FT-847
I use LogHX + MSHV in my second QTH with FT-847 transceiver. Due to the specific properties of the transceiver, it is necessary to use a separate COM port, connected to the Data in/out terminal for modulation and PTT. (I also use USB interface SCU-17 but this is not important at this point.)
However, it is important that I have to manually close this COM port before running MSVH (this port is normally used for PTT/CW).
Question: Would it be possible to add "Close PTT/CW port" to be added to MSHV settings (or other external programs)?
Note: For FT-847 and digital modes, PTT via CAT cannot be used (TX modulation would not pass).
Thank you for reading, 73 Josef OK2WO
30.08.2022, 12:55 #525
- 03.02.2006
- 51
- 17,253
- 8059
- 4230
