25.08.2013, 07:34 #1261High Power
- 16.08.2004
- Астана
- 861
- 296
- 151
Абсолютно верно, открываем мануал, находим распиновку разъема на передней панели, тыкаем пару раз паяльником, вуалуя и готово.
Да и еще не забываем выполнить рекомендации:
New Kenwood TS-590 Setup Recommendations
Kenwood's exciting new TS-590S transceiver promises to be popular among active operators throughout the world. We are already getting a lot of questions about the best "settings" for the on-board DSP microphone equalizer.
The TS-590S does have a very sophisticated software-programmable equalizer system, but that's not required in order to get on the air while sounding great.
Menu items 25 and 26 set the transmitter's bandwidth. Leave them at factory defaults to get started; they'll set you up for a low-end cutoff of 300 Hz, and a high-end cutoff of 2700Hz.
Now go to Menu #30, and select "C" ("Conventional"), which will give the audio frequencies above 600Hz a slight (3 dB) boost. That will be good for starters. You may also select "HB2" (High Boost 2) if you're using a wide-range microphone, like the PR 781, on the TS-590. The High Boost 2 selection will suppress the lower frequencies, and give you more "sparkle" on the high side, for good communication-quality audio.
Ultimately, though, much of the fun of acquiring a new radio is the experimentation with its many features. Read the operating manual, especially on page 32, and then try out the many available bandwidths and equalization possibilities. Listen to yourself on a separate receiver, with its antenna disconnected and its noise blanker turned off, to know exactly how you'll sound to others listening to you on the air.
For best results please consult your manual.Последний раз редактировалось UN0LL; 25.08.2013 в 07:38.
Владимир UN0LL
25.08.2013, 10:34 #1262Покинул форум
- 21.06.2009
- 55
- 3,676
- 2030
- 2226
Подключите - отпишитесь, пожалуйста, по вашим впечатлениям. Тоже с пол года назад приобрел такую гарнитуру - чувствительность самого элемента оказалась очень низкой. По сравнению со штатным микрофоном и даже по сравнению с HC-4. Приходится наворачивать усиление чуть ли не на всю. Где то читал, что сами элементы собирают в Китае, качество каждого экземпляра сильно отличается, поэтому это лотерея... Да, вопрос не по теме, но все же... Может у кого есть ссылка, где можно приобрести отдельно элементы HC-6 для гарнитуры?
Последний раз редактировалось UT5IA; 25.08.2013 в 10:43.
25.08.2013, 13:33 #1263Very High Power
- 17.08.2002
- ko85mo, RDA MO-56
- 2,985
- 396
- 159
В Мире радио продавали. Вместе со штангой только. Да, и вроде еще в Радиоэксперте видел. Тоже со штангой (к наушникам крепить).
Михаил, RK3FW
25.08.2013, 19:50 #1264High Power
- 17.11.2009
- 503
- 304
- 1076
Добрый вечер.
Не совсем по теме,но рядом.
Кто нибудь состыковывал бэнд-декодер RU-005 от r-quad с трансивером? Проблема в том что не могу даже "обучить" декодер.В трансивере менял только скорость СОМ порта .Может ещё что надо вкл-выкл в меню? Или надо лезть глубже?В бирюльки играю на все фитюльки.
25.08.2013, 23:55 #1265Very High Power
- 29.11.2010
- пос. Птичное - теперь часть Москвы в 30 км к Юго-Западу от МКАД
- 2,381
- 1328
- 596
Стыкуется и работает отлично. Только одно но... Программировать RU-005 нужно только с компьютера. Скачиваем с сайта производителя программу, там есть описание, как шнурок соединительный распаять. Далее запускаем прогу, выбираем наш трансивер и программируем все участки диапазонов. А в ручную он не захотел с Kenwood TS590 программироваться.
Игорь RL5A
07.09.2013, 16:35 #1266Very High Power
- 07.09.2013
- Губкин
- 4,721
- 1257
- 373
Использую гарнитуру HEIL PRO SET ELITE HC-6 уже год вместе с TS-590S.Установки через програмный эквалайзер ARCP-590.Правда уже несколько раз переустанавливал,получается всё лучше и лучше с каждым разом. Токи покоя не трогал и не собираюсь.Кому мало чувствительности микрофона,можно попробовать собрать схемку на КТ3102 и попробовать через неё.Сделал для своего FT897D и такой же гарнитуры,получилось не плохо.С АКОМОМ состыковал,всё классно.Только пиковая мощность по показометру больше чем в режиме нажатия.Поэтому нужно не перекачивать РА(любой),иначе проблемы.
14.09.2013, 18:41 #1267Very High Power
- 10.01.2006
- Йошкар-Ола
- 3,322
- 1724
- 2539
Хочу спросить, у кого какие настройки приемника!?
У меня так:
IF-FIL (в основном) 200-2600.
AGC в SSB: SLOW-17.
AGC в CW: FAST-5.
RX-EQ в SSB:
0 (-5), 300 (1), 600 (-5), 900 (-3), 1200 (-2), 1500 (0), 1800 (2), 2100 (4), 2400 (5), 2700 (3), 3000 (-3), 3300 (-11), 3600-5100 (-24).
RX-EQ в CW:
0 (-24), 300 (-7), 600 (6), 900 (-7), 1200-5100 (-24).
Интересно, как у других!?73, Константин
21.09.2013, 15:35 #1268
21.09.2013, 15:44 #1269Very High Power
- 10.01.2006
- Йошкар-Ола
- 3,322
- 1724
- 2539
В оконцовке поставил НВ2 в меню 31 (RX-EQ) для SSB, отменный звук.
На этом эксперименты с радио заканчиваю
буду тупо работать в эфире.
73, Константин
21.09.2013, 15:44 #1270Заблокирован
- 20.01.2008
- 3,152
- 1220
- 2301
21.09.2013, 17:27 #1271High Power
- 04.02.2007
- деревня Аксеново КО94
- 603
- 234
- 1736
Недавно прикупил 590-й для второго места. А вчера подоспел посылкой SM (STATION MASTER) от microHAM. С компом соединил по USB, а с трансивером по RS232. SM подключил к коммутатору RK226 ( в 12-ти вольтовом исполнении) от RQuad. Великолепно все управляется и коммутируется. Так что мой 590-й запущен в работу. Если ещё кто колеблется с коммутацией - советую. 590-й дружит с SM .
Александр.
26.09.2013, 12:14 #1272Very High Power
- 05.05.2011
- Краснодар
- 3,893
- 2941
- 1322
Слышал сам и читал про проблемы с качеством SSB сигнала у TS-590. Как сейчас с этим вопросом? Всё такие же выпускаются или исправили?
26.09.2013, 13:42 #1273
26.09.2013, 14:11 #1274Big Gun
- 24.09.2011
- 14,704
- 5079
- 5900
Трансиверы KENWOOD всегда славились своими сигналами (на протяжении десятилетий), но сигналы TS-590 "это нечто". Худший из всех предыдущих моделей. Приемник сделали великолепный, передатчик г..но.
Александр, UA8U (ex. RZ9UI, RA9UGR)
26.09.2013, 15:55 #1275Standart Power
- 25.10.2012
- Удомля, Тверская обл.
- 237
- 153
- 211
У меня TS-590, рядом живут еще два обладателя этого трансивера, у всех совершенно нормальный сигнал и ни кто с инструментом в них не залезал. Просто нужно внимательно, обдуманно и ответственно отнестись к многочисленным настройкам трансивера и все будет хорошо иначе действительно вылезают всякие некрасивые интонации. "Образцовые установки" многократно публиковались. А приемник в нем действительно замечательный !
73 Андрей RV3ID DXCC HR #1
620Спасибо
