Страница 85 из 229 ПерваяПервая ... 357578798081828384858687888990919295135185 ... ПоследняяПоследняя
Показано с 1,261 по 1,275 из 3432
Like Tree620Спасибо
Тема: TS-590S: опыт эксплуатации
  1. #1261
    High Power Аватар для UN0LL
    16.08.2004
    Астана
    861
    296
    151
    Абсолютно верно, открываем мануал, находим распиновку разъема на передней панели, тыкаем пару раз паяльником, вуалуя и готово.
    Да и еще не забываем выполнить рекомендации:
    New Kenwood TS-590 Setup Recommendations
    Kenwood's exciting new TS-590S transceiver promises to be popular among active operators throughout the world. We are already getting a lot of questions about the best "settings" for the on-board DSP microphone equalizer.
    The TS-590S does have a very sophisticated software-programmable equalizer system, but that's not required in order to get on the air while sounding great.
    Menu items 25 and 26 set the transmitter's bandwidth. Leave them at factory defaults to get started; they'll set you up for a low-end cutoff of 300 Hz, and a high-end cutoff of 2700Hz.
    Now go to Menu #30, and select "C" ("Conventional"), which will give the audio frequencies above 600Hz a slight (3 dB) boost. That will be good for starters. You may also select "HB2" (High Boost 2) if you're using a wide-range microphone, like the PR 781, on the TS-590. The High Boost 2 selection will suppress the lower frequencies, and give you more "sparkle" on the high side, for good communication-quality audio.
    Ultimately, though, much of the fun of acquiring a new radio is the experimentation with its many features. Read the operating manual, especially on page 32, and then try out the many available bandwidths and equalization possibilities. Listen to yourself on a separate receiver, with its antenna disconnected and its noise blanker turned off, to know exactly how you'll sound to others listening to you on the air.
    For best results please consult your manual.
  2. #1262
    Покинул форум
    21.06.2009
    55
    3,676
    2030
    2226
    Цитата Сообщение от UA9FGJ Посмотреть сообщение
    Приобрел HEIL HC-6
    Подключите - отпишитесь, пожалуйста, по вашим впечатлениям. Тоже с пол года назад приобрел такую гарнитуру - чувствительность самого элемента оказалась очень низкой. По сравнению со штатным микрофоном и даже по сравнению с HC-4. Приходится наворачивать усиление чуть ли не на всю. Где то читал, что сами элементы собирают в Китае, качество каждого экземпляра сильно отличается, поэтому это лотерея... Да, вопрос не по теме, но все же... Может у кого есть ссылка, где можно приобрести отдельно элементы HC-6 для гарнитуры?
  3. #1263
    17.08.2002
    ko85mo, RDA MO-56
    2,985
    396
    159
    В Мире радио продавали. Вместе со штангой только. Да, и вроде еще в Радиоэксперте видел. Тоже со штангой (к наушникам крепить).
  4. #1264
    17.11.2009
    50
    486
    303
    1054
    Добрый вечер.
    Не совсем по теме,но рядом.
    Кто нибудь состыковывал бэнд-декодер RU-005 от r-quad с трансивером? Проблема в том что не могу даже "обучить" декодер.В трансивере менял только скорость СОМ порта .Может ещё что надо вкл-выкл в меню? Или надо лезть глубже?
  5. #1265
    Very High Power Аватар для RL5A
    29.11.2010
    пос. Птичное - теперь часть Москвы в 30 км к Юго-Западу от МКАД
    2,381
    1329
    596
    Цитата Сообщение от UA6AFN Посмотреть сообщение
    Добрый вечер.
    Стыкуется и работает отлично. Только одно но... Программировать RU-005 нужно только с компьютера. Скачиваем с сайта производителя программу, там есть описание, как шнурок соединительный распаять. Далее запускаем прогу, выбираем наш трансивер и программируем все участки диапазонов. А в ручную он не захотел с Kenwood TS590 программироваться.
  6. #1266
    07.09.2013
    Губкин
    4,671
    1249
    365
    Использую гарнитуру HEIL PRO SET ELITE HC-6 уже год вместе с TS-590S.Установки через програмный эквалайзер ARCP-590.Правда уже несколько раз переустанавливал,получается всё лучше и лучше с каждым разом. Токи покоя не трогал и не собираюсь.Кому мало чувствительности микрофона,можно попробовать собрать схемку на КТ3102 и попробовать через неё.Сделал для своего FT897D и такой же гарнитуры,получилось не плохо.С АКОМОМ состыковал,всё классно.Только пиковая мощность по показометру больше чем в режиме нажатия.Поэтому нужно не перекачивать РА(любой),иначе проблемы.
  7. #1267
    Very High Power Аватар для RU4SS
    10.01.2006
    Йошкар-Ола
    3,317
    1724
    2536
    Хочу спросить, у кого какие настройки приемника!?
    У меня так:
    IF-FIL (в основном) 200-2600.
    AGC в SSB: SLOW-17.
    AGC в CW: FAST-5.
    RX-EQ в SSB:
    0 (-5), 300 (1), 600 (-5), 900 (-3), 1200 (-2), 1500 (0), 1800 (2), 2100 (4), 2400 (5), 2700 (3), 3000 (-3), 3300 (-11), 3600-5100 (-24).
    RX-EQ в CW:
    0 (-24), 300 (-7), 600 (6), 900 (-7), 1200-5100 (-24).
    Интересно, как у других!?
  8. #1268
    High Power Аватар для R1OO
    29.02.2008
    Ратибор
    945
    171
    364
    Цитата Сообщение от RL3Q Посмотреть сообщение
    в 79 ом меню поставте 204 и тогда нажимая PF A будет включаться в режиме Tune.мощность регулируется как обычно
    если хотите что бы включалось кнопкой PF B то это же значение надо установить в 80 ом меню.
    Да везде
    В этом случае перестаёт переключатся антенный вход 1,2.
  9. #1269
    10.01.2006
    Йошкар-Ола
    3,317
    1724
    2536
    В оконцовке поставил НВ2 в меню 31 (RX-EQ) для SSB, отменный звук.
    На этом эксперименты с радио заканчиваю буду тупо работать в эфире.
  10. #1270
    20.01.2008
    3,152
    1220
    2301
    Когда? если в меню занести те значения которые я говорил?
    или когда включена доп. приемная антенна?
    У меня все нормально,в любом случае ант1/2 переключается нормально!!!
  11. #1271
    04.02.2007
    деревня Аксеново КО94
    603
    234
    1729
    Недавно прикупил 590-й для второго места. А вчера подоспел посылкой SM (STATION MASTER) от microHAM. С компом соединил по USB, а с трансивером по RS232. SM подключил к коммутатору RK226 ( в 12-ти вольтовом исполнении) от RQuad. Великолепно все управляется и коммутируется. Так что мой 590-й запущен в работу. Если ещё кто колеблется с коммутацией - советую. 590-й дружит с SM .
  12. #1272
    Very High Power Аватар для UA6AA
    05.05.2011
    Краснодар
    3,891
    2939
    1320
    Слышал сам и читал про проблемы с качеством SSB сигнала у TS-590. Как сейчас с этим вопросом? Всё такие же выпускаются или исправили?
  13. #1273
    29.11.2010
    2,381
    1329
    596
    Рулетка. Покупал новый - попался с поганым SSB.
    Купил с рук старого выпуска - получил с отменным качеством SSB сигнала. Просто супер!
    Что-то там похоже не подбирают или не отстраивают на заводе.
    Вот и получается - как повезет...
  14. #1274
    Big Gun Аватар для UA8U
    24.09.2011
    14,527
    5036
    5859
    Трансиверы KENWOOD всегда славились своими сигналами (на протяжении десятилетий), но сигналы TS-590 "это нечто". Худший из всех предыдущих моделей. Приемник сделали великолепный, передатчик г..но.
  15. #1275
    Standart Power Аватар для RV3ID
    25.10.2012
    Удомля, Тверская обл.
    237
    153
    211
    У меня TS-590, рядом живут еще два обладателя этого трансивера, у всех совершенно нормальный сигнал и ни кто с инструментом в них не залезал. Просто нужно внимательно, обдуманно и ответственно отнестись к многочисленным настройкам трансивера и все будет хорошо иначе действительно вылезают всякие некрасивые интонации. "Образцовые установки" многократно публиковались. А приемник в нем действительно замечательный !
  1. Опыт эксплуатации антенны OPEK-300
    от RA0ZHM в разделе Антенны УКВ
    Ответов: 34
    Последнее сообщение: 10.02.2025, 07:18
  2. TS-950SDX: опыт эксплуатации
    от R2PM в разделе TS-950
    Ответов: 168
    Последнее сообщение: 29.03.2021, 04:09
  3. Опыт создания и эксплуатации УМ (5-10 кВт)
    от UT9MZ в разделе Усилители мощности
    Ответов: 461
    Последнее сообщение: 03.09.2016, 17:51
  4. MacLoggerDX + HamRadioDeluxe 5: опыт эксплуатации
    от R3ABM в разделе Аппаратные журналы
    Ответов: 7
    Последнее сообщение: 03.07.2011, 11:29
  5. Ответов: 14
    Последнее сообщение: 07.05.2008, 01:02
