26.07.2024, 10:44 #871QRPP
- 25.07.2024
- 4
26.07.2024, 15:55 #872Координатор темы
- 03.02.2006
- 53
- 20,649
- 10158
- 5456
Ant.: UW4HW, Pwr.: ~500 Wtts
27.07.2024, 01:28 #873QRPP
- 05.01.2024
- 41
- 6
31.07.2024, 11:20 #874QRPP
- 25.07.2024
- 4
My skin setting is
12.08.2024, 14:34 #875QRP
- 07.07.2023
- 16
Still UDP Multicast working on this new version build 765?
12.08.2024, 16:46 #876Координатор темы
- 03.02.2006
- 53
- 20,649
- 10158
- 5456
Fixed problem with UDP Multicast -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_766.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
29.08.2024, 23:14 #877Standart Power
- 03.01.2021
- 196
- 18
Hello,
starting with version 765, and later 766 and 767, there are problems opening the local file managers.
versions 763 and 764 work correctly.
Thanks.
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
30.08.2024, 10:38 #878Координатор темы
- 03.02.2006
- 53
- 20,649
- 10158
- 5456
Fixed - try this:
http://rx4hx.qrz.ru/files/loghx/test..._build_767.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
30.08.2024, 19:27 #879Standart Power
- 03.01.2021
- 196
- 18
31.08.2024, 09:54 #880Standart Power
- 03.01.2021
- 196
- 18
ICOM IC-7600
With version 767 [ something changed in the management of the cat when transmitting in split.
Now, even if I set FREQA, it always reads the frequency FREQB, the one where I transmit in split.
Instead it should remain FRQA where I receive the dx station.
V763 work fine with cat.
Thanks for your attention
01.09.2024, 08:15 #881Координатор темы
- 03.02.2006
- 53
- 20,649
- 10158
- 5456
Fixed, please test -
01.09.2024, 19:40 #882Standart Power
- 03.01.2021
- 196
- 18
02.09.2024, 11:21 #883Координатор темы
- 03.02.2006
- 53
- 20,649
- 10158
- 5456
02.09.2024, 15:35 #884Standart Power
- 03.01.2021
- 196
- 18
Hi Alexey,
ICOM IC-7600 does not have two separate vfos.
when in split mode,
the VFOA (FreqA) is fixed on the receive frequency, (red arrow on the bandmap) (in the log as RX FREQ)
the VFOB (FreqB) you move it to the desired transmit frequency.
(blue arrow on the bandmap) (in the log as TX FREQ)
Please check, until version 763 everything worked fine.
02.09.2024, 17:47 #885Координатор темы
- 03.02.2006
- 53
- 20,649
- 10158
- 5456
167Спасибо
